front sway bar
Old Feb 5, 2008 | 04:12 PM
ctgreddy's Avatar
ctgreddy
Default front sway bar
is there any advantage to taking off the front sway bar. I keep hearing things about it giving you a faster 1/4 mile time but does it make the car feel sloppy if you take it off? reason im asking is im putting on new control arms and this would be the best time to take it off if theres any benefit in doing so. thanks for any replys.
Old Feb 5, 2008 | 05:22 PM
stang8689's Avatar
stang8689
Default RE: front sway bar
It saves weight and is not needed to go straight but it help on the strret for cornering
Old Feb 5, 2008 | 05:37 PM
gearbanger's Avatar
gearbanger
your not going to lose much in the 1/4 the sacrafise is not worth it imo..
Old Feb 5, 2008 | 07:23 PM
nseoi's Avatar
nseoi
dont do it if you are a daily driver. track cars only IMO. stangs are sloppy around corners as it is, you dont need to make them looser lol
Old Feb 5, 2008 | 09:43 PM
ctgreddy's Avatar
ctgreddy
would it be worth it taking it out before i go to the track or something?
how much time does it take off? i cant imagine it doing much of anything buy you never know.
Old Feb 5, 2008 | 10:36 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
the reason people remove the sway bar in part is not just for weight savings..... by removing it....it allows the free travel of the front control arms to lift easier and quicker....hence allowing weight transfer to occur quicker by allowing front to raise quick with out the sway bar limiting travel /lift of the front lower control arms ..it'll most benifit 60 ft times
Old Feb 6, 2008 | 02:28 AM
w8less's Avatar
w8less
agred.
when i took my front sway bar off the car dfeinitely was lifting faster
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
winner99
Oct 1, 2015 01:06 PM
winner99
Oct 1, 2015 10:52 AM
mdg
Oct 1, 2015 07:04 AM
