help me please!!!!!!!!!!!!
Old Feb 6, 2008 | 07:02 PM
chris93LX's Avatar
chris93LX
Default help me please!!!!!!!!!!!!
I got a 93 LX 5.0 and it boggs out at 4000rpms exactly. Replaced the fuel tank,pump,and filter.If you drive calm it will run thru it but when ur on it it dont want to go past 4000rpms
Old Feb 6, 2008 | 07:33 PM
stangbanger87's Avatar
stangbanger87
Default RE: help me please!!!!!!!!!!!!
has it been chipped have a throttle enhancer on it or any mods at all? could be in the rev limiter . we kinda need to know what all it has or if it stock to try to track it down.
Old Feb 6, 2008 | 07:41 PM
chris93LX's Avatar
chris93LX
I was told it is all stock. I bought a throttle position sensor but didnt put it on yet. I just got the car about 6 months ago.
Old Feb 6, 2008 | 10:33 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
is the spout connector in or did it fall out???? also try cleaning the maf with the proper cleaner
Old Feb 7, 2008 | 12:14 AM
chris93LX's Avatar
chris93LX
I cleaned the maf and what spout connector ?this is my first stang.
Old Feb 7, 2008 | 05:49 PM
chris93LX's Avatar
chris93LX
p
Old Feb 7, 2008 | 06:00 PM
5.0stanger's Avatar
5.0stanger
The spout connector is a black jumper plug....
Old Feb 7, 2008 | 09:55 PM
dimebag's Avatar
dimebag
how is it? like no fuel? valve float?
get a little more descriptive about what exactly it does at 4k
right now thoughts are
tfi
valve float(doubtful)
coil
maf
Old Feb 7, 2008 | 10:17 PM
chris93LX's Avatar
chris93LX
if ur on it at 4k it does not want to pick up it breaks up. but if ur about half on the pedal it will run to 7k if u want it to and if ur past 4k and jump on it it like u hit the brakes. there are no mods that i know of except exhaust. Im not sure what else to sayIm glad u ppl r tring to help thanx
Old Feb 8, 2008 | 03:35 AM
maiello2169's Avatar
maiello2169
ORIGINAL: mjr46
Got my stang for $2000 because of this. Look very closely at the MAF sensor because I thought I had it clean the first time around...but later took it out to find gunk all over it. Make sure you clean it in a well lit area so you can make sure the filaments are good and clean.
