timing questions-timing problems
Old Feb 16, 2008 | 01:33 AM
pk222's Avatar
pk222
Default timing questions-timing problems
hey guys, I tried to check my timing a while ago, before i knew about the spout connector. then put a new cap, rotor, plugs and wires on.
problem is when I tried to check the timing with the spout connector off the timing would bounce back and forth. How can I fix this? What could It be, slack in my timing chain?
If I sound retarded I'm sorry I'm 16 and dont know anything about ignition.
Thank you for any input possible
Old Feb 16, 2008 | 12:37 PM
bowtieless's Avatar
bowtieless
Default RE: timing questions-timing problems
bouncing back in forth as in you can't really tell what it is at all? i had this problem once with an aftermarket cam and high volume oil pump.... ended up it was chewing up the cam gear and ruined the motor.... so mark the distributor on the block and pull it out and check the teeth on the dist. gear and the cam gear. they should look kinda thick and have a wear pattern on them... if they are sharp you're in trouble. hope this helps
Old Feb 16, 2008 | 01:15 PM
pk222's Avatar
pk222
thanks again, and It's at 10 degres I think and then it will bounce away and then back too it.
Old Feb 16, 2008 | 02:58 PM
bowtieless's Avatar
bowtieless
huh....check all connections really well... it should light up and stay really steady.....just make sure you put the distributor back in the exact same place!!!!
Old Feb 17, 2008 | 12:54 PM
pk222's Avatar
pk222
all the connections look good and are tight so could it be the timing chain? and if it is how can i check it?
Old Feb 17, 2008 | 01:35 PM
Hung Like a Stang's Avatar
Hung Like a Stang
if your timing is bouncing like that with your spout it, thats timing chain and gears.
Old Feb 17, 2008 | 07:25 PM
AdderMk2's Avatar
AdderMk2
Banned
did you check the timing with the car at full operating temp?
do you get a steady idle?
Old Feb 17, 2008 | 10:07 PM
bowtieless's Avatar
bowtieless
i meant make sure the timing light has a good connection on the plug wire.... PULL THE DIST AND CHECK THE GEAR!
Old Feb 19, 2008 | 02:03 PM
pk222's Avatar
pk222
ya it took a while to get the car at a steady idle while not haveing the spout connector connected but i got it to idle at about 900 rpm, and I'm pritty sure the connection to the spark plug was good.
i'll check the gear on the dist soon and if that doesn't help then ill get a new timing chain and gears. any other possible small things it could have been?
thanks for all your help
djbigskrilla
Sep 20, 2022 01:04 AM
Cin K
Aug 31, 2015 07:31 AM
stormesixx
Aug 25, 2015 09:11 AM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
