Spring Compressor
Old Feb 27, 2008 | 07:55 PM
68CSTANG's Avatar
68CSTANG
Default Spring Compressor
Does someone make a coil spring compressor specifically for Fox bodies? Ive heard people talk about it before but no-one seems to know where to get one. Anybody have any links to one? At one point I think I remember someone saying Ford makes one but Im not for sure. These springs are giving me fits. Thanks
Old Feb 27, 2008 | 08:09 PM
ryan_89_mustang's Avatar
ryan_89_mustang
Default RE: Spring Compressor
I've heard of people compressing them normaly then stapping them tight and taking the compresser off
Old Feb 27, 2008 | 08:12 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
put a jack under the control arm after setting spring in place.......I had mine on a lift so I secured body to the lift and used the weight of the car to ut them in place... or have a few people sit on top of the fender while jacking into place
Old Feb 27, 2008 | 08:34 PM
68CSTANG's Avatar
68CSTANG
Ive also heard of people strapping them but I dont have any kind of strap that could hold that much pressure.
Old Feb 27, 2008 | 08:38 PM
mjr46's Avatar
mjr46
well then place a jack under control arm the best you can and jack it up using weight of car to compress and then seriously have a few people sit on top the fender being careful not to dent it
Old Feb 27, 2008 | 08:51 PM
Maxwelhse's Avatar
Maxwelhse
When I did mine I did exactly what mjr is telling you to do, minus the people on the fender. My car came off of the jackstand by about 1/2" and stayed right there until the bolts where in. I did, and do recommend, using a second jackstand for safety incase something should happen to go wrong. Meaning you should have 3 jackstands supporting the front of the car when doing this (2 on the side that you're lifting).
Old Feb 27, 2008 | 09:05 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Link
Old Feb 27, 2008 | 10:46 PM
68CSTANG's Avatar
68CSTANG
Thanks for the link Pro but heres my dilema: Ive tried a compressor like that and the spring has to be compressed so far that the threaded stem is too long and wont fit. Basically the stem ends up being alot longer than the spring. Im putting in Drap springs and theyre the same height as stock. Thanks
Old Feb 28, 2008 | 02:29 AM
AdderMk2's Avatar
AdderMk2
Banned
you dont need a spring compressor..
ive swapped springs 4 times in my car and havent used a compressor yet
Old Feb 28, 2008 | 04:06 PM
68CSTANG's Avatar
68CSTANG
How did you do that Adder? Drop the control arm and then jack under it?
