Guaranteed To Pass....?
Need to pass emmisions this week. Has anyone had any luck with guaranteed to pass? Ive got a carbed engine, with smog delete, but have the cats on. Just want to know if you think this guarnteed to pass forumla stuff will work? If i dont get good reveiws then i will probably lean towards running some acetone? Anycomments or advice on which i should do?
it makes very good sense.... tune the carb the best you can, make sure the timing is set correctly and the cats are working well.
I passed with two hi flow cats, 14 degrees of timing, no smog, all with flying colors, I am f/i as well.
well im just tryin to pass the test, thast why the cats are there, why wouold that be a failure in the future? Anyways thanks for answering the question, thanks to who did though.
Diode Dynamics
28
May 26, 2022 12:02 PM
