which header?
Old Mar 29, 2008 | 09:19 PM
PFCAiello's Avatar
PFCAiello
Default which header?
is the ford racing shorty any good? im also looking at bbk and heddman. anything a much better bang for the buck?...which shorty is the best flow wise and ease of install? and ill be running a off road h-pipe if it matters
Old Mar 29, 2008 | 11:32 PM
stang8689's Avatar
stang8689
Default RE: which header?
I have BBK ceramics, good but if sit too lung start to rust
Old Mar 30, 2008 | 12:56 AM
Rajun_Cajun's Avatar
Rajun_Cajun
I would get BBK. I've heard nothing but good things about them. As fas as the coating starting to rust after a period of sitting, that goes for most ceramic coatings. The reason for this is bc the coating isnt completely cured until ran through several heat cycles.
Old Mar 30, 2008 | 12:59 AM
ctgreddy's Avatar
ctgreddy
yeah id go bbk. however for shorties you can either get unequal lengths which flow better than stock and install is easier. or theres the equal lengths which flow better than the unequals but the install is a little tougher.
Old Mar 30, 2008 | 12:07 PM
PFCAiello's Avatar
PFCAiello
is the ceramic worth the extra cost?
Old Mar 30, 2008 | 12:21 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: PFCAiello
Yes, mine are 2 years old and still look new. The ceramic coating also helps reduce the temp at the header.
Old Mar 30, 2008 | 12:26 PM
PFCAiello's Avatar
PFCAiello
ORIGINAL: PRO50SC
ORIGINAL: PFCAiello
hey pro, what brand are yours?
Old Mar 30, 2008 | 03:37 PM
jperz89lx's Avatar
jperz89lx
i just put in ceramicbbk equal lengths in my car...they were a pain in the **** to put in...had to jack the engine up to make it easier[:@]...but now that everything is done they look amazing
Old Mar 30, 2008 | 03:42 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: PFCAiello
ORIGINAL: PRO50SC
ORIGINAL: PFCAiello
BBK ceramic coated equal length shorties
Old Mar 30, 2008 | 03:51 PM
PFCAiello's Avatar
PFCAiello
ORIGINAL: PRO50SC
ORIGINAL: PFCAiello
ORIGINAL: PRO50SC
ORIGINAL: PFCAiello
ok thanks yours looked good, at least from the bottom
