valve covers?
Old Apr 2, 2008 | 11:35 AM
kweb288's Avatar
kweb288
Default valve covers?
ok i have a quick question, will the stock valve covers work on aluminum heads? was looking at the Canfield 195's and would like to keep the old ones if at all possible at this point in time....dont know if you need this information but the rr are 1.6
Also i have the 1.6 rr on my stock heads right now (think these are called pedastal mounted..) would i need to uprade to a different style with aluminum heads, or are these ok?
Thanks for the help, and if you need anymore info then what i put down to answer my q's just let me know
Old Apr 2, 2008 | 03:27 PM
Mustangkiler's Avatar
Mustangkiler
Default RE: valve covers?
If its a stud mount head you need either get new rockers or get the crane conversion kit and yes you could use stock Fox valve covers as long as there is no baffles.
Old Apr 2, 2008 | 03:46 PM
kweb288's Avatar
kweb288
sweet on the valve covers! once less item to buy and i like the look
Old Apr 2, 2008 | 07:06 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you may have to clearance the baffles a little and or install a double gasket
Old Apr 2, 2008 | 08:07 PM
kweb288's Avatar
kweb288
red neck engineering at its finest
Old Apr 2, 2008 | 08:08 PM
kweb288's Avatar
kweb288
Old Apr 2, 2008 | 08:11 PM
mjr46's Avatar
mjr46
^^^^talk to my77stang....he actually designed a trick gasket set up with crush spacers
Old Apr 2, 2008 | 08:16 PM
stang8689's Avatar
stang8689
I like aftermarket valve covers, you spent how much for those heads, get some used Ebay ones
Old Apr 2, 2008 | 08:55 PM
kweb288's Avatar
kweb288
eh, along with the possible torque converter, lt's, mid pipe, cam, intake, fuel injectors, fuel pump, and everything else it adds up and i can always slap them on later.
Old Apr 2, 2008 | 11:42 PM
primetime5.0's Avatar
primetime5.0
I stock covers with no baffles on my comp cams pro magnums..
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
