331 stroker questions
Old Apr 5, 2008 | 08:21 PM
92sleeper's Avatar
92sleeper
Default 331 stroker questions
Whats going on everyone,I got a few questions.A buddy of mine has just purchased a 331 stroker motor w/10.5 to 1 compression.
Performer RPM Heads ported and custom lift cam 560 lift.
Right now he has 24lb injectors in his car with a 65mm throttle body and pro-mass air 80mm that he had on his 306.
The question is what injectors,mass air,and throttle body does everyone recommend for the 331 stroker motor or should he stay with the stuff he has.
Old Apr 5, 2008 | 08:33 PM
CantStopTheFox...'s Avatar
CantStopTheFox...
Default RE: 331 stroker questions
The 24s are good if he keeps that setup.......Make sure the MAF is calibrated to the injectors....
The TB can be bigger.....maybe 70 or 75......what type of intake is on it?
Old Apr 6, 2008 | 01:17 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
use the 24's for now but have it dyno tuned and have a/f checked and that'll tell you if the pump and injectors are capable of the combo
Old Apr 6, 2008 | 08:42 AM
92sleeper's Avatar
92sleeper
so your saying the 24 lb injectors should be good enough fuel for the 331 if everthing is calibrated right
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
