emissions...couple questions
well my car is all stock except for the exhaust with no cats and im missing my smog pump .. but the engine is very clean only 32k .. do you guys think if i set the timing at 10 i could pass inspection like that in new york ...
also would it be worth it or pass if i put a new smog pump on there ?
wouldi feel a loss of power ?
what would i need to replace the smog pump ? are there any connectors i should look for ? i still have the charcoal cannister and the pipe running from the back of the heads but the pipe is capped .. do i need hoses ? thanks guys
For inspection do they really open your hood to check around? For emmisions don't they just hook up an engine diagnostic to check? Where I live if your check engine light isn't on you're fine. Plus in NH they only check the year 96 and up not that helps you I guess.
ORIGINAL: ponyboy302
no they dont really look around ... im not saying i wont pass because the smog pump is missing .. im asking if having the smog pump will help me pass when they test the car ..
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
