NO ROOM UNDER THERE
Old Apr 15, 2008 | 10:41 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
Default RE: NO ROOM UNDER THERE
ORIGINAL: 84Stanger302
Mine was stock until i dropped the clutch at a light and the clutch pedal went to the floor...that was an interesting drive home let me tell you!
my brother has snapped 2 clutch cables, i cant imagine the looks you get when you blow through stop signs because you cant afford to stop
Old Apr 16, 2008 | 01:50 AM
JalapenoNotch0's Avatar
JalapenoNotch0
for those of you who did it in 10 minutes, how in the heck did you get all of those springs loose so quickly??
Old Apr 16, 2008 | 05:23 AM
ArmchairDeity's Avatar
ArmchairDeity
Spring pliers?
This one's for brakes, but the idea works for lots of springs:
Old Apr 16, 2008 | 09:22 AM
84Stanger302's Avatar
84Stanger302
haha yea i stop though.. and then crank the engine over in first gear and give her plenty of gas! It isnt good for anything but hey it got me home!
Old Apr 16, 2008 | 09:35 AM
AdderMk2's Avatar
AdderMk2
Banned
you dont have to remove the springs to get the quadrant off.
Once you have the cable disconnected from the clutch fork, you reach up under the dash with a pair of needle nose pliers, pull out the two pins that hold the quadrant in place. Release the pawl, and slide the quadrant off to the side.
I pulled a quad from a fox, and installed it in another in 35 minutes. Including the time it took me to disconnect the cables!
Old Apr 16, 2008 | 09:55 AM
WhiteWindsor's Avatar
WhiteWindsor
I'm 250 lbs. I did it fairly quick without removing my seat. You just have to keep adjusting yourself untill youfind that sweet spot that makes enough room for you to work.
SteelerNation82
Mar 9, 2025 11:40 AM
baddog671
Jul 26, 2016 01:20 PM
teeeeg67
Sep 1, 2015 11:53 PM
69FB
Aug 18, 2015 08:50 PM
