backfire
Old May 1, 2008 | 11:57 AM
MY88GT5.0's Avatar
MY88GT5.0
Default backfire
Hey quick ? Sometimes when i start up the stang once in a great while when i rev it up some it will backfire, It never does it when driving tho and only when the engine seems to be cold. Could it have something to do with the fact that i have no cats justa xpipes and mufflers?? car runs and drives perfect to. Any advice would be greatly appreciated thanks!
Old May 1, 2008 | 12:03 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
Default RE: backfire
mine does this too but i think i've linked it to leaky injectors. so i picked up 8 new injectors free so i'm going to swap em out and see what happens. i've set, checked EVERYTHING and mine still backfires a bit at first start up and smells of raw fuel. after its run for a minute or two all these symptoms are gone.
Old May 1, 2008 | 12:08 PM
MY88GT5.0's Avatar
MY88GT5.0
Thats funny because i smell fuel sometimes to u think the new injectors will work to solve the problem??
Old May 1, 2008 | 12:11 PM
89mustangfive0's Avatar
89mustangfive0
funny i see this thread i smell fuel to and if i let the car get warm...its fine..no backfire...
Old May 1, 2008 | 01:32 PM
FivePointOhh
in limbo
im not sure if its the same for the both of you, but i know my backfires on cold start and it smells of fuel pretty bad until i get her goin for a couple minutes and burn out all that fuel thats been sittin for a while. i'll update you tonight if it helps with the new injectors.
Old May 1, 2008 | 01:36 PM
MY88GT5.0's Avatar
MY88GT5.0
Thanks i will be curious to no if it helps!
Old May 1, 2008 | 01:57 PM
Albizo66's Avatar
Albizo66
well when your car is cold, to warm it up the computer dumps lots of fuel in, so it runs very rich at cold start up..and since you have no cats it jsut sits there..
Old May 1, 2008 | 02:33 PM
Hollister Hoodlum's Avatar
Hollister Hoodlum
Simple, DONT REV YOUR ENGINE TO 5500 RPM WHEN ITS COLD!!
that is all
Old May 1, 2008 | 03:42 PM
FivePointOhh
in limbo
ORIGINAL: Hollister Hoodlum
that is all
what are you talking about. its just idling and if i put any load on the car its "pop pop pop pop" little bitty backfires and she holds back as if she has the e brake on. i'm not going WOT or anything im just trying to drive off. i dont know about those other guys but thats my issue. she doesnt run right until my temp registers on my guage at 100* then all the resistance and backfiring stops
Old May 2, 2008 | 08:24 AM
FivePointOhh
in limbo
UPDAAAAAAAAAAAAATE
replaced injectors with the newer ones and my problem has been solved, no more backfires or resistance on cold start up. she purrrrrrrrrrs
