Timing?
Old May 8, 2008 | 01:55 PM
thrty5thsc's Avatar
thrty5thsc
Default Timing?
Hi folks... I have an 86 5 liter. I want to advance my timing a little bit. What is my mark, The point or the circle? Also what doyou have your timing set at?
Thanks alot!!!!!!!!
Old May 8, 2008 | 02:12 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Timing?
The point/flat spot of the pointer. The other is for a magnetic probe. Mine is set at 10* for my set up. My wifes is set at 14*
Old May 8, 2008 | 06:38 PM
thrty5thsc's Avatar
thrty5thsc
Default RE: Timing?
I must be doing something wrong. When I checked the timing going by the pointer it's at almost 40degrees!! How can that be? If that's correct i would think it would not start or turn over. The car starts right up everytime with no trouble.
Old May 8, 2008 | 09:19 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Timing?
ORIGINAL: thrty5thsc
the tip/pointer is the one to use..also did you pull the spout to check/set base timing???
Old May 8, 2008 | 09:23 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Timing?
https://mustangforums.com/m_1531258/mpage_1/key_/tm.htm#1531258
Old May 9, 2008 | 11:45 AM
camaroeater's Avatar
camaroeater
Default RE: Timing?
I always have my eyes looking straight(no angle)at the pointer. Adjusting the timing is something you definately want to research before hand.
Old May 9, 2008 | 04:03 PM
thrty5thsc's Avatar
thrty5thsc
Default RE: Timing?
What spout? I am frustrated!! I used to know everything about these cars. My first car was an 83 gt with a t5and it was way faster than this one. I was 16 at the time, now i'm 33 and I don't have a clue. What spout and what do I do? Take me toschool!!
Thanks for the help!!!
Old May 9, 2008 | 04:05 PM
thrty5thsc's Avatar
thrty5thsc
Default RE: Timing?
The timing light is the ones with the dial on the back. My #1 is on the pass side right? 5.0 HO with AOD.
Old May 9, 2008 | 04:07 PM
thrty5thsc's Avatar
thrty5thsc
Default RE: Timing?
Hey thanks for that link PRO50SC. I'm looking at it right now!
Old May 9, 2008 | 04:18 PM
camaroeater
Default RE: Timing?
Yes...put the clamp on #1 spark plug wire(about 6 inches from spark plug boot) and make sure that the arrow on clamp is pointingTOWARDS #1 spark plug not towards distributor. Keep clamp and wire to clamp away from headers....don't wanna burn anything.
