WHERE TO GET CHEAP SHIFTER???"
Old May 8, 2008 | 04:49 PM
sofob0909's Avatar
sofob0909
Default WHERE TO GET CHEAP SHIFTER???"
like it said. where can i get a short shifter for like 140 range. I want something that is reliable and wont be a POS. im also looking for an adj. clutch cable.
Im looking to spend a total of $200 and get...
short shifter, clutch cable, and "t-style" ****.
Would a big show be the place to go and get one direct?
[align=left] [/align]
Old May 8, 2008 | 04:54 PM
945LSTANG's Avatar
945LSTANG
Default RE: WHERE TO GET CHEAP SHIFTER???"
aftermarket cables are ****. ive gone through a steeda cable and a upr cable. each lasted about 9 months. stick with the oem cable.
as for a quadrant and firewall adjuster, i like my steeda setup.
btw...200 for everything you listed will probably get you low quality products.
Old May 8, 2008 | 05:14 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: 945LSTANG
$200 will get him really low quality products.
Plan on spending about $175 on a shifter, $20-25 on the ****, and $60-$100 on a quadrant/cable/adjuster setup
Old May 8, 2008 | 07:29 PM
sofob0909's Avatar
sofob0909
is the oem cable adjustable????
I want the clutch to grab higher and less quickly. it grabs all at once. what do i need to get this done?
Old May 8, 2008 | 08:00 PM
5.0kid's Avatar
5.0kid
Im not sure if the oem cable is adjustable but you will need a clutch quadrant
Old May 8, 2008 | 08:01 PM
sofob0909's Avatar
sofob0909
what will that do???????????
Old May 8, 2008 | 08:06 PM
5.0kid's Avatar
5.0kid
well it allows you to adjust where the clutch starts to engauge. i have a upr line though so all i had to do is install it and turn the quadrant untill i like where it was. I haven't had a problem with my cable at all and i drive and hour a day every day with the car.
Old May 8, 2008 | 08:11 PM
bdptcob's Avatar
bdptcob
Check craigslist. I picked up a pro 5.0 shifter for $100 on there.
5.0kid's Avatar
5.0kid
I have a Hurst Short Throw shifter and stick with a ball **** ill sell for $35.00 + shipping cost
Old May 8, 2008 | 08:30 PM
sofob0909's Avatar
sofob0909
can i see a picture?????
