94 GT Problems
Old May 14, 2008 | 06:46 PM
cbassett1's Avatar
cbassett1
Default 94 GT Problems
I have a 1994 mustang GT 5.0 manual trans. that will sputter when it hot or cold and when we press down on the gas fully then we receive minimal power(slow rise in rpms) until we get to approx. 2000 rpms in which we will not get any more power. However we can still gain speed or get power above if we are lightly touching the gas. The current gear is not the problem. We can be on a 15 degree grade uphill and still be slowing down(not very fast but still slowing down)with the gas at full throttle but with just a little bit of throttle, we will get better response. Basically, on level or uphill grade, with the throttle at full we have extremely little power/response. but with very minimal throttle we get more power/response. Our beliefs is that it is the calytic converter.
Old May 14, 2008 | 08:05 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: 94 GT Problems
run a koer test for codes if none ..check fuel pressure..if adequate pressure and volume...loosen doen pipes up to simulate an exhaust leak and if the cats are plugged you'll get power back
Old May 14, 2008 | 09:16 PM
AdderMk2's Avatar
AdderMk2
Banned
I've got my money on the cats.... it happened to me
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
