NEW GUY
Old May 16, 2008 | 12:06 AM
victormedina4688's Avatar
victormedina4688
Default NEW GUY
hey i have a 1987 mustang gt ive got:
89 5-speed computer,
edlebrock heads,
B303 cam,
1.72 rockers,
3.55 gears,
world class T-5,
GT40 upper/ lower intake,
70mm mass air and TB,
SSC headers,
aluminum radiator
and drive shaft,
2.5 ' high flow cats,
2 chamber flow master mufflers,
155 lph in-tank
and 255 lph in-line fuel pumps,
24 lb injectors,
fuel pressure regulator,
air/fuel gauges,
lakewood traction bars,
center force heavy duty clutch
and adjustable clutch quadrant.
Subframe connectors,
new oil pump and
double timing chain.
Now i want to take of the smog pump but i dont know which is best ... to replace it with a pulley or get a shorter belt?
also what do u guys think about takin off the fan and replacing it with an electric fan good move?
THANKS
Old May 16, 2008 | 12:14 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: NEW GUY
replace it with a pulley so you don't get belt stretch by tring to bypass it and eventually the two ends rub together shreading the belt.......done it both ways..pulley works best ...see:
http://i242.photobucket.com/albums/f...347pics002.jpg
Old May 16, 2008 | 12:15 AM
Does Not Exist's Avatar
Does Not Exist
Default RE: NEW GUY
I just ordered the smog pump delete pulley...didn't even think of doing a shorter belt. D'OH![:@]
Electric thingys are always wonderful to have, IMO. I've got my eye on an electric water pump....
Does Not Exist
Default RE: NEW GUY
ORIGINAL: mjr46
Sweet! Sounds like I made the right "decision".[8D]
Old May 16, 2008 | 12:22 AM
mjr46's Avatar
mjr46
Default RE: NEW GUY
ORIGINAL: boostin95cobra
ORIGINAL: mjr46
in regards to what???? the pulley???
Old May 16, 2008 | 12:23 AM
Does Not Exist
Default RE: NEW GUY
Yes, sir.
Old May 16, 2008 | 12:27 AM
mjr46's Avatar
mjr46
Default RE: NEW GUY
cool!! yeah I got tired of the look without it and after 2-3 month the belt would stretch and trust me there was no in between belt with my set up / meziere elec water pump that'd work..so finally I just bought the pulley for the clean look and it cured the belt stretch/touching issue
Old May 16, 2008 | 12:32 AM
Does Not Exist
Default RE: NEW GUY
Old May 16, 2008 | 12:43 AM
mjr46's Avatar
mjr46
Default RE: NEW GUY
How much did your pulley set ya back? I just paid $75.[:@][:@][:@]
I'm thinkin of doing the A/C delete next...don't really need A/C in Colorado.
I think this is what I got so 53.00.........
http://store.summitracing.com/partde...p;autoview=sku
Old May 16, 2008 | 12:50 AM
Does Not Exist
Default RE: NEW GUY
Mine looks a whole lot fancier...[8D]
