i know im a newb but i need some help. inthe back of the lower intake there is a screw in 3/4 inch fitting that a hose connects to. there is no hose on it, what does it go to. when i feel up the radiator coolant/ water just pour out of it. thanks.
here is a pic but u cant see it. it is on the back of the lower intake.sorry i couldn't get a better pic but u can see the vacinity. it is a 91 gt 5.0
[IMGhttp://i97.photobucket.com/albums/l219/wiljersey/100_1106.jpg[/IMG]
its not workin so try this
http://i97.photobucket.com/albums/l2...y/100_1106.jpg
are you sure you have the coolant hose from the backside of the throttle body connected to the nipple on the coolant tube pipe and not a vaccum connection??[&:]...looks as if that open rubber hose may go to that but hard to tell?? to my nowledge there are no coolant connections on a efi car in the rear lower intake..the coolant tubes that run alongside the passanger valve cover to heater core are only connections back there with the t connector to throttle body
