MSD Ignition Install *PICS*
Old May 21, 2008 | 01:24 AM
cdougherty's Avatar
cdougherty
Default MSD Ignition Install *PICS*
Would anyone mind showing me where you mounted your MSD box? I've got a 90 Fox, Charger and factory batter location and NOW things are tight in there. I was wondering if any of you have a similar setup and have a sweet spot to still put it in the bay? Pics would be helpful!
Old May 21, 2008 | 05:02 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Default RE: MSD Ignition Install *PICS*
It is time for a battery relocation my friend! Many people mount it there. I have mine where your battery sits but my battery is located on the other side from the factory. I am supposed to have the overflow/windshield washer resevoir there but I never put it back on my car.
But for alternate locations
under passenger seat
glove box
remove arm rest and mount there
passenger side trans tunnel (inside the car)
I doubt you do but if you had a SN dash swapped into it you can mount it inside the passenger air bad compartment. That is where I will be mounting mine once I get the swap done.
Old May 21, 2008 | 05:10 AM
9 Sec 93 LX's Avatar
9 Sec 93 LX
Battery to the back time.
I have all electrics on one side, all fuel related items on the other.
[IMG]local://upfiles/95778/224FCD3F58244673958A6C0FE88D08C2.jpg[/IMG]
[IMG]local://upfiles/95778/C6FBE7EE1BA947D2BF8C2F2E5CC214AD.jpg[/IMG]
Old May 21, 2008 | 07:31 AM
stang8689's Avatar
stang8689
Battery to the trunk
Old May 21, 2008 | 07:32 AM
stang8689's Avatar
stang8689
sorry I thought I resized that first pic
Old May 21, 2008 | 07:59 AM
smythge's Avatar
smythge
Here is a pic of where mine is, battery in the trunk.
Old May 21, 2008 | 08:33 AM
WhiteWindsor's Avatar
WhiteWindsor
Pic is in sig. MSD and relays mounted on plexi-glass on passenger side.
Old Jun 8, 2008 | 09:37 AM
cdougherty's Avatar
cdougherty
Thanks for the options guys. I bought a relo-kit but decided it against it. I didn't want to deal with having to drop the tank, etc. So, I ended up mounting the MSD under the driver seat. It barely gets warm there, it's easy to access if I want to replace the RPM jumpers and running/extending the wiring was a breeze. A word of note for anyone who wants to do this:
[ul][*]Make sure you buy the correct gauge wire if extending (MSD recommends going one gauge up on the power/ground wires) *wire gauge is opposite. So if you have a 16G wire, you'd use a 14G.[*]Extend all wires, run them through the firewall and leave plent of it hanging out until you're ready to trim and make connections[*]You don't have to extend the ground wire. It's long enough and you can mount it to the inside of the car body under the carpet. I chose to run mine back up through the firewall and mounted it to the inside fender (driver) just behind the battery, there's already a grounding spot there.[*]I have a convertible and almost chose the spot behind the rear seat where the convertible top pump is mounted. PLENTY of space in there for all kinds of goodies! I just didn't want to lengthen wire that long. [/ul]
Old Jun 8, 2008 | 09:30 PM
stang8689's Avatar
stang8689
You don't have to drop the tank to relocate the battery. BTW this is an old thread
Old Jun 8, 2008 | 11:53 PM
cdougherty's Avatar
cdougherty
Really? Well, i'd have a heck of a time getting my hand up under there. If you've got some info on where the two mounting screws go I may give it a try.
I realize this is an old thread (a few weeks) but I hate reading threads that have no resolution to them. So, I figured I come back for one last update.
If you want, PM me with info on the relo. I'm telling ya though, I didn't say ANY way I coudl get my hand up there to reach at least one of the mounting bolts.
