Power steering pump removal/installation?
May 22, 2008 | 05:26 PM
I need to change my power steering pump, but i cant seem to fit the pully remover between the pully and the coolant tank. Is the normal? do i move the tank or what
Any tips to help?
thanks
May 22, 2008 | 05:40 PM
RE: Power steering pump removal/installation?
You need a different puller and install tool rather than your standard puller to remove andreinstall the pulley.
You can rent the puller from AutoZone I believe (for Free ).
May 22, 2008 | 05:53 PM
This is the removal tool;it clamps over the nose piece of the pulley.
This is the install tool you'll need.
May 22, 2008 | 05:57 PM
yeah thats what i got from advance auto but i cant figure it out
May 22, 2008 | 06:01 PM
maybe the remover i have is longer or something but it looks the same
May 22, 2008 | 06:07 PM
You're clamping the clam shell piece around the nose pieceof the pulley, and then threading it into the center part ?
May 22, 2008 | 06:15 PM
maybe i have a different end piece. Do you have to use it with an end piece?
May 22, 2008 | 06:16 PM
Quote:
ORIGINAL: BlackBetty93GT
This might help some?
May 22, 2008 | 06:17 PM
yeah but i dont have enough room to twist the bolt into the nut, the end of the bolt i have to put it between the space in the coolant tank
May 22, 2008 | 06:26 PM
