ford racing 3.73's
So I'm building a 8.8 right now for my 92 and I finished up with the trac loc unit tonight and got the races for the pinion in and wheel bearings in and my question is: I've always heard not sure if it's a myth or not that the ford racing gears reuse factory shims for easy set up..???? anyone got any LINKS TO SUCH CLAIM??????????....mine are real ford racing ones not made by motive!!!......and I'm not really concerned with setting up the rear as I have the correct factory tools to set up and measure for the shim for the pinion bearing.......and dial indicator for backlash and inch lbs wrench for pinion preload on crush collor....just WANTED to see if any one has any such articles
When I installed my Ford racing 3.73's from the factory 2.73's I was able to reuse the factory pinion shim but I had to add shims to the drivers side of the carrier and take away from the passenger side to get .010" backlash. It has been a couple of years since I put them in so I can't remember the exact amount. Have fun with the crush sleeve, I had to use a cheater bar laying on my back tourqing the pinion nut to get the proper preload on the pinion bearings, good times
^^^^^^^ahhh crush sleeve will be easy..screw the breaker bar deal...small blips on the IR 231 FTW!!!..i ACTUALLY HAVE ALL THE FACTORY rotunda tools for checking pinion depth.....just wanted to see if the myth is true......were your gears noisey at all??
ORIGINAL: bighungrymatt
we reused ours too when I did my gear install, no whining and works great! went from 3.08 to 3.73
ORIGINAL: blwn93gt
iinstalled the ford racing 3.73's as well. reused all the factory shims. no noise or anything.
