ford racing 3.73's
RE: ford racing 3.73's
ORIGINAL: mjr46
well not gonna happen in my case..did the set up this evening and have to finish it all tommorrow but to make a long story short ...the heel contact was low and high toe contact on the coast side with factory .017 pinion shim....gotta add some more shim to get correct contact pattern and do it in .003 increments and the carrier shims allowed for too much back lash .016 to be exact not the optimalrange of .008 to .012 so I'll be resetting it up in the morning..I corrected the backlash but pinion depth is a little off still[:@]
ORIGINAL: blwn93gt
iinstalled the ford racing 3.73's as well. reused all the factory shims. no noise or anything.
ORIGINAL: red95gtconvert
That's kind of how it worked out for me too, using the factory carrier shims I had way to much backlash, after reshiming a few times I ended up with .010" backlash and called it good. My gears came out of my f150 and had about 8K miles so they have a slight whine at 1400 rpms but not reallybad at all. I've had them in the carfor about 9K miles and so far so good.
ORIGINAL: mjr46
ORIGINAL: blwn93gt
yeah, gears are something you want to take your time doing and not skip any steps. if mine would have been off i would be doing the same thing that you are. atleast your gonna take the time to do it right.
you measure ****? damn... we did mine by feel lol... atleast you did them the right way
i went from 3.27s to 3.73s in my 02, reused all the shims and its perfect, no noise no nothing, backlash was awesome as was everything else
gotta love how that works out.... most of the time
ORIGINAL: dimebag
squishbang
Suspension
11-02-2015 03:42 PM
