how big a slick...
can I put on the old 10 hole rims? I measured them and they are 8 and a 1/4 wide, so does that mean I can only go 8 inches wide? Or can I put something a bit bigger?
Thanks
Thanks
ORIGINAL: Jasperstang308
i thought they were a 15x7. your talking about a stock rim correct or you talking about a weld rim?
thats exactly what i did. So you can run a 10 inch slick on it then. ok
ORIGINAL: PRO50SC
They are. He probably measured from end to end and not where the bead rests
I have a set of mt et streets 26x10.50x15 on my ten holes and like Pro50sc said they will ballon a little as mine do..but none the less you can do it
here's a vid of them on my 92
http://s242.photobucket.com/albums/ff63/mjr46/?action=view¤t=nvmc21003.flv
