Restoring or painting molding on car....
Old May 27, 2008 | 01:26 PM
DoctorD415's Avatar
DoctorD415
Default Restoring or painting molding on car....
I'm currently painting my car and have all the moldings off of it. I want to paint and get the molding ready myself so i was wondering if anyone has some insight on this.
First of all, its rubber so i know that you need to spray some flex paint primer first correct. Then after that what have people used for paint. I want the charcoal/black color. If anyones done this let me know. Thanks.
Old May 27, 2008 | 01:29 PM
88BlueGT's Avatar
88BlueGT
Default RE: Restoring or painting molding on car....
what molding are you referring to ??? it makes a difference. If you are talking about door molding, etc. I paint my moldings with regular autozone black molding paint. Suprisingly, it works really well. I painted some molding on my friends older BMW and its held up really nicely for over a year now with no problems.
Old May 27, 2008 | 01:36 PM
DoctorD415's Avatar
DoctorD415
Ya every molding around the car. The rubber door and side fender ones, and also the plastic fender ones in the back.
I'm also goin to need to paint the plastic molding around the convertible top? Any idea no what to use for that?
Old May 27, 2008 | 03:13 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: DoctorD415
do yourself a favor and if you haven't all ready and the mouldings are off the car pull the metal backing off with a pair of pliers to with the doublesided tape was stuck to so mouldings will lay flat...I used TRIM BLACK BY SEM...and has held up for 5 years so far..if you wish to paint with a single stage after that then by all means do so
Old May 27, 2008 | 03:42 PM
DoctorD415's Avatar
DoctorD415
Trim Black by sem...ive heard of people using that a few times now, i think i might go with th at. Did you just like degrease the molding and make sure it was clean then just give ti a few coats?
Should this paint work for both the rubber moldings and the plastic molding around the vert top and do generic stores carry this, whered you get yours?
Old May 27, 2008 | 05:14 PM
stang8689's Avatar
stang8689
SEM trim black works for everything. Yes clean them first then said with 320 or 400. The metal molding will probably need primer first. I would sand everything with 320 till theres no gloss, clean with wax and grease remover, then prime everything with 3 light coats of primer. Then sand with 400and blow them off and wipe them down . Now 3 light coats of trim black.
Old May 27, 2008 | 06:01 PM
88BlueGT's Avatar
88BlueGT
I have never used SEM's trim paint but I have used their SEM Landau Black to paint my interior. Held up great.
Old May 27, 2008 | 10:21 PM
DoctorD415's Avatar
DoctorD415
You would even prime the rubber door moldings? What paint would use for that? It has to has to somesort offlex additive in it right?
Which of these two would i use?
http://sem.ws/Catalog.asp?prod=132
or
http://sem.ws/Catalog.asp?prod=133
or
http://sem.ws/Catalog.asp?prod=130
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Oct 1, 2015 09:29 AM
b8checker
Sep 30, 2015 07:11 AM
GLOCKer
Sep 28, 2015 07:36 AM
