tire rub
Old Jun 7, 2008 | 11:45 AM
jonnysubmarine_USN's Avatar
jonnysubmarine_USN
Default tire rub
so i put some 245s on the front. and theres some rubbing would it actually be rubbing the struts or just the panel that hangs down. anybody else have this issue. or an answer. thanks
Jon
Old Jun 8, 2008 | 10:06 AM
stang8689's Avatar
stang8689
Default RE: tire rub
Is the car lowered? Normally it will rub the strut on a full turn, you can get rack limiters for that.
Old Jun 8, 2008 | 10:22 AM
jonnysubmarine_USN
no the car is stock height
Old Jun 8, 2008 | 10:48 AM
USMC1775's Avatar
USMC1775
I thought you could get wider than a 245 on foxes..?
My SN I have 275 up front on a 9" wheel and it sometimes rubs at full turn on the front swaybar.
Old Jun 8, 2008 | 11:17 AM
AdderMk2's Avatar
AdderMk2
Banned
your tires will NEVER rub on the strut, unless they were rubbing it as soon as you put the wheels/tires on
Old Jun 8, 2008 | 11:33 AM
Albizo66's Avatar
Albizo66
my front right rubs on the inner fenderwell at full lock turning the wheel left.
i only have 215's, but they are stretched on the '96 cobra rims im running (dumb *** previous owner did it)
yet, my front left never rubs when fully locked either way (there is no inner fenderwell on that side)
Old Jun 8, 2008 | 11:37 AM
93 LX FiveO's Avatar
93 LX FiveO
245's usually rub upfront on foxes
you can get limiters or run a smaller tire
i run a 255 in the rear and it barely fits
Old Jun 8, 2008 | 12:33 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
my front only rubs on hard turns (granted the tire is a good, 1/4 of an inch from the fender, thats inward, i need to raise it) but on full turns my wheels grind on the A arms
Old Jun 8, 2008 | 02:06 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
What size rim and what backspacing do you have?
Old Jun 8, 2008 | 05:47 PM
jonnysubmarine_USN
yeah i only have a rub on full turn.
