brake lights dont work
Old Jun 10, 2008 | 07:11 PM
jonnysubmarine_USN's Avatar
jonnysubmarine_USN
Default brake lights dont work
so i was driving down the road and someone told me my brake lights were out. so i stopped by the local auto store and put some new bulbs in. that didnt work. so i have two thoughts. theres a burnt fuse or my brake light switch is out. my buddythinks it might be a short, but i am not quite sure that it is because all my other lights work except for my brake lights. am i on the right track. also how hard is it so change a brake light switch?
Jon
Old Jun 10, 2008 | 07:15 PM
87foxgt's Avatar
87foxgt
Default RE: brake lights dont work
does your dash lights work??
Old Jun 10, 2008 | 07:24 PM
jonnysubmarine_USN
yes, all my light workaccept my brakes. turns, front and back head lights all them.
Old Jun 10, 2008 | 07:42 PM
87foxgt's Avatar
87foxgt
do you have hazard lights??
Old Jun 10, 2008 | 07:44 PM
jonnysubmarine_USN
yeah i forgot to mention those but they work as well.
Old Jun 10, 2008 | 07:56 PM
5.0kid's Avatar
5.0kid
try to see if the light wire is disconected near the top of the brake pedal i had the exact same problem and all i had to do is push the two quick connect bungs together and it worked
Old Jun 10, 2008 | 07:58 PM
87foxgt's Avatar
87foxgt
find out if there is power going to the lights by testing it...it does not sound like fuse... sounds like switch is off or bad...
Old Jun 10, 2008 | 08:04 PM
jonnysubmarine_USN
thanks i'll try both of those. quick question for both. first for 5.0kid about how far up is the plug, and is it hard to get to. second for 87foxgt how hard is it to replace the switch, and how do i tell if it is off. thanksagain for the help. and i'll get back to you when i find out what the issue is.
Old Jun 10, 2008 | 09:02 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
check the brake light switch down on the pedal
Old Jun 10, 2008 | 09:21 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: mjr46
just unplug it and run a jumper between the pins... lights should pop on
