cam question
heyy ...i have an 89 gt and i want to install a e303 cam whats the labor usually cost on the installation just a ballpark estimate would be awesome
thanks |
RE: cam question
why e303? my buddy has one and i dont like the way it sounds at all. my suggestion is stay away from the letter cams and get a comp cam.
RE: cam question
i was thinking of the e303 or the f303. i just installed the gt40 upper & lower intakes and today i picked up some gt40p heads. why the comp cam, just sound or performance or both? would the cam that comes in the v8 explorers add any power or is it the same as the stock 5.0? sorry to jack your thread but i was going to start the same one.
RE: cam question
ORIGINAL: 1GT2NV heyy ...i have an 89 gt and i want to install a e303 cam whats the labor usually cost on the installation just a ballpark estimate would be awesome thanks |
RE: cam question
ORIGINAL: wiljersey i was thinking of the e303 or the f303. i just installed the gt40 upper & lower intakes and today i picked up some gt40p heads. why the comp cam, just sound or performance or both? would the cam that comes in the v8 explorers add any power or is it the same as the stock 5.0? sorry to jack your thread but i was going to start the same one. the explorer cam is garbage. way worse than the stock 5.0 cam. also when you switch to thoes heads make sure you swap the springs for ones that will handle ur cam. |
RE: cam question
^^^^comp xe series cams are nice ots cams....mine works well!!..you'll like them;)
RE: cam question
thanks i think im going to replace the springs, valves, rods, etc.... and i know its expensive to have them port and polished but is it worth it
RE: cam question
the trickflow stage 1 cam sounds amazing...
RE: cam question
dont just add the cam its a waste. not worth the work for the gain
RE: cam question
thanks guys its partly for both power and sound but mainly to get my foot in the door of internal motor work
