cleaning ponies
Hey guys,
I found a really good deal on a set of ponies locally. They look to be in fairly good shape and come with nice tires. I can tell they need a good cleaning wich is fine by me. But they guy described them as "faded" and in the first pic, you can see that some of the center caps look weird. Is this cause the centercaps are plastic? If so i'll prolly just get new centercaps. Also, how can I clean these up real well? Do they have the same clearcoat finish as 10 holes?
Heres some pics. Judging from the pics, do they look like they can be cleaned up pretty good?
It is notorious for ponies that after a while, the paint begins to fade on the wheel. That looks to be the case here, they look like they are in good shape. I would buy them and scuff them up with some scotch brite pads and maybe some 800 grit sand paper, and repaint them with standard wheel paint, but be sure to clear them afterwards. They could look as good as new for less than $50.
ORIGINAL: haromaster87
Thanks man, would I be okay using the wheel paint that comes in a can?
ORIGINAL: ctgreddy
I think thats what he means, i used that duplicolor paint on my old eclipse rims and they worked fine, but put atleast 3 coats of clear on or they'll chip easily.
