Finall
with a stock 85 block ,f-cam ported e7's and roller tip rockers and performer 289 intake and 600 carb I's run 13.70's /13.80's with 3.45 gears in a 7.5 which is now toast and it has an 8.8 now with 3.73's
its a 88 motor, i basically just put all new gaskets on it. new oil pan, timing chain, timing cover, waterpump, harmonic balancer, and an edelbrock rpm air gap intake. Along with nitrous.
painted it, and put the headers on it, so yes its basically a painted stock motor. with spray.
you'll be fine with a 100 shot..just pull 2-3 degrees timing to be on the safe side like if base was 10 degrees ..maybe run 8 base degrees.. for saftey and make sure bottle pressure is at least 900psi to hit hard and purge it when rolling up to the line and spray your heart away!!
ORIGINAL: Hollister Hoodlum
Alright thanks, yeah i bought a purge kit and a pressure gauge.
still have to get the blow down tube though [:@]
ORIGINAL: mjr46
blow down tube??? my purge kit from NOS came with evertything
Thanks again for all the comments guys.
Now i just can't wait to get it all in the stang
Jan 21, 2016 01:30 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
