trans help
Old Jul 10, 2008 | 06:59 PM
01snake's Avatar
01snake
Default trans help
i am curently thinking about selling my car and picking up a 87 mustang by me
the car has a 460c.i. motor in it all the guy knows is 600+hp.........
the problem is..........he wants to sell it as is and the car's trans went out (only has reverse) i believe he said it was a TCI?
where can i find a trans online that would be a direct swap that will hold this kinda power?
OR how much would a trans cost from a transmission shop roughly?
Old Jul 10, 2008 | 07:29 PM
01snake's Avatar
01snake
Default RE: trans help
i just got the mod list..... tell me what you guys think!!
· Frame Tied, 10-point cage painted purple.
· Granatelli Tubular K-Member, Coil Overs, A-Arms.
· Competition Engineering Struts (90/10) and Competition Engineering rear shocks adjustable set at 50/50.
· Paint – Lexus Pearl with purple graphics.
· Aerospace Components front disc assembly with Aerospace Components rear dual calipers and full assembly. Proportioning valve, lines, hardware, etc. Set up for manual brakes.
· Weld drag lites with brand new front runners as well as brand new rear BF Goodrich tires 275/65/15. Extra set of Weld Drag lites for slicks as well.
· Fiberglass 2 ½ inch cowl with pro stock hood scoop on top of cowl.
· Flaming River manual rack and steering shaft
· Southside upper and lower control arms
Fuel System
· Barry Grant 280 fuel pump
· Stock deep sumped tank
· -10 fuel like to Barry Grant 4 port regulator. Aeromotive fuel filter and all Aeroquip fittings.
· -8 return line w/ aeromotive fuel filter.
· Pro-Systems Dominator sits on ported Edelbrock Victor 460. Dominator matched and flowed.
· BG fuel pressure gauge on BG 4 port regulator.
· Taylor Batter Box mounted in trunk area with brand new Optima battery
Engine
· 460 bored .30 over. 11-1 pistons.
· 70 Dove heads ported w/ Crane Roller Rockers off set 1.6 / 1.72
· Erson solid cam 705-inch lift.
· Cobra Jet Crank and rods
· Full length headers
· Custom Motor plate
· Motor has around 675-700hp
· Nitrous motor – was going to spray a 150-200 shot
· March pulleys
· Motorsport alternator
· Ignition – MSD 7al - MSD distributor – MSD coil Blaster 3.
· Moroso batter cut off switch
Exhaust
· 3 ½ inch custom exhaust by Great Lakes Custom in Mt. Clemens.
· 3 Inch Flowmaster 2 chamber mufflers dumped before rear axle.
· Extra set of Borla XR-1 Race Mufflers 3 ½ inch available.
Trans
· TCI Reverse Pattern C-4
· Coan 5000 stall
· Aluminum motorsport driveshaft
· Cheetah SRC Shifter
· Cheetah command center wired for fuel pump, electric fan, start, ignition, windows, and head lights.
Trans is blown. Only reverse is working. Need to have trans rebuilt or replaced with other. C-4 may not be the way to go.
Rear End
· Ford Mototrsport 8.8 rear end
· 31 Spline axles
· 373 motorsport gears.
· New V-8 rear springs
New aluminum radiator good for 1000hp. Autometer Ultra Lite Fuel pressure, fuel level, volts, water temp, monster tach with shift light and recall, and nitrous pressure gauges. RJS 5 point harnesses. Interior needs to be somewhat finished. I am sure I am forgetting something. I don’t think there is a part of this car I have not changed. Approximately 675-700hp on motor alone.
Old Jul 10, 2008 | 09:12 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you need one stout c-4 to handle that big block power or a stout c-6
Old Jul 11, 2008 | 01:14 AM
01snake's Avatar
01snake
how much roughly for a built c-4 or c-6?
i can go manual if i have too............
and any places to buy these?
Old Jul 11, 2008 | 01:52 AM
jtmustang's Avatar
jtmustang
i have built many big block fords and been around them my whole life and from that list i can tell u that motor is not making 700 hpand that cam on that setup is a little big as it looks.
how much for the car and any pics?
Old Jul 11, 2008 | 06:26 AM
BlessedHellride's Avatar
BlessedHellride
Check out RedNeck Performance on Ebay. I have heard nothing but good things about their stuff and they are about the cheapest builder that I have seen. They build C4's to with stand 850 horsepower. I have also heard that they were tied in with Art Carr also. His trannies also come with a custom built convertor to you specified stall range. I got mine delivered for $1240 bucks. He has a warranty also I think on his trannies. They are out of Dallas, TX.area.
I wouldn't run a manual behind a big block myself, but that is my opinion. Go with a built automatic, more consistant, less likely to miss gears and a little easier on the driveline.
Old Jul 11, 2008 | 12:07 PM
bighungrymatt's Avatar
bighungrymatt
also curious to how much he is asking for it
Old Jul 11, 2008 | 02:08 PM
68CSTANG's Avatar
68CSTANG
700hp sounds a little higher than I would expect it to make...but who knows...and maybe look into a powerglide or a well built C4.
Old Jul 11, 2008 | 06:58 PM
01snake's Avatar
01snake
i could pick the car up for 11g's
Old Jul 11, 2008 | 08:55 PM
ZachW04Stang's Avatar
ZachW04Stang
Contact performance automatic. There supercomp should handle that kind of power. It cost around $2000 if I remember correctly but has a lifetime warrenty, you only have to pay shipping.
