EVERYONE Please Read !!!
Old Jul 13, 2008 | 07:25 PM
Explosive's Avatar
Explosive
Default EVERYONE Please Read !!!
Alright, I was just using the torque wrench to put the flywheel onto the crank. I was almsot finished but when I approached the ARP listed 62 Ft LBS they stripped I think at least 2-3 holes are stripped. Is this common with them ? They appear to be way shorter than the stock bolts. Should we try and reuse the old bolts since the go much deeper and would grab onto good threads? I'd hate to have to tear the motor down again.
P.S. Never use ARP Flywheel bolts.
Old Jul 13, 2008 | 08:37 PM
primetime5.0's Avatar
primetime5.0
Default RE: EVERYONE Please Read !!!
Ive used the stockers many many times.. just re use them
rmodel65's Avatar
rmodel65
Yukon Cornelius
did you get flywheel bolt or flexplate bolts??
Old Jul 13, 2008 | 09:11 PM
Explosive's Avatar
Explosive
I beleive it's the same part number.
Old Jul 13, 2008 | 09:20 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
normally the flywheel bolts are longer since the flywheel is thicker, than a flexplate
Old Jul 13, 2008 | 09:21 PM
bighungrymatt's Avatar
bighungrymatt
I have ARP flywheel bolts and didnt have any problems with them, I have reused them too...
Old Jul 13, 2008 | 09:37 PM
Explosive's Avatar
Explosive
ORIGINAL: rmodel65
Yea we had already figured that one out upon looking at it. Basically we told the guy at the counter what we needed, he ordered the bolts, we got flex plate bolts. So yup, bolt was too short and so they stripped. Live and learn I guess.
So heres out new plan, stock bolts are 1". We buy some grade 8- 1 1/4" those will grab a little more thread and make up for the stripped stuff.
Heres a pic of the stripped stuff,
Old Jul 13, 2008 | 10:07 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you should be able to repair that on the car and install helicoils....holes don't go all the way through
Old Jul 13, 2008 | 10:12 PM
Explosive's Avatar
Explosive
ORIGINAL: mjr46
They do actually, we have the motor from the 87 parts car, I pulled the oil pan off and looked. they go through, and have about 1/4" of room to play with before they touch anything inside.
Old Jul 13, 2008 | 10:17 PM
mjr46's Avatar
mjr46
that's odd.. I've never had a stock roller block crank that had the holes all the way through, if that is the case you'll need loctite on them to seal off oil from entering past threads and creating an external oil leak
