interior lights wont turn off
Old Jul 23, 2008 | 08:01 PM
93 LX FiveO's Avatar
93 LX FiveO
Default interior lights wont turn off
ive been taking bits and pieces of the dash apart and today i finaly got the bottom of the center console out and the trim around the heater controls.
i shut the door to my car and the lights wont turn off. i tried playing with the spring in the jam and it dosnt do anything.
finaly i whacked the light itself and it went out then came back on [sm=dontgetit.gif]
Old Jul 23, 2008 | 08:13 PM
ctgreddy's Avatar
ctgreddy
Default RE: interior lights wont turn off
do fox's have a warning light on the dash for when the doors are open? if so is it on when the door is closed.
if yes to both of those then i'd guess your switch or the wiring for the switch is bad.
Old Jul 23, 2008 | 08:25 PM
93 LX FiveO
no
i did play with the dimmer switch, dont know if there is any relation to the dome light.
i plan on taking the instrument panel out once i get a torx bit that fits under the windshield
Old Jul 23, 2008 | 08:47 PM
1heaney's Avatar
1heaney
Dome lights? What light are you referring too?
Old Jul 23, 2008 | 08:53 PM
93 LX FiveO
yes the dome light
Old Jul 23, 2008 | 08:56 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
make sure the dimmer switch/ wheel isn't positioned to the spot where it turns dome light on
Old Jul 23, 2008 | 09:01 PM
1heaney's Avatar
1heaney
ORIGINAL: mjr46
make sure the dimmer switch/ wheel is positioned to the spot where it turns dome light on
OH YES! That would do it Hhaaahahaha! if that doesn't work try this (what I posted)https://mustangforums.com/m_5307966/tm.htm
Old Jul 23, 2008 | 09:16 PM
93 LX FiveO
well mjr is right but the switch did not click right to activate the dome light so its probably just stuck on or something.
i disconnected the battery and the cluster will come out once i get that torx bit tomorrow at work so i can fudge with it
Old Jul 23, 2008 | 09:20 PM
mjr46's Avatar
mjr46
unplug the switch and see if they go out with doors shut of course
Old Jul 23, 2008 | 09:41 PM
1heaney's Avatar
1heaney
ORIGINAL: mjr46
Yes do that before tearing into the cluster for sure!
