computre help
Old Jul 31, 2008 | 10:44 PM
kremer306's Avatar
kremer306
Default computre help
I have a 91 mustang 5.0 bored .30 over with alm. heads trick flow stage 2 cam trick flow intake. for the injection system 80 mm mass off a lincoln cold air intake 70 mm bby throttle body bbk fule pressure regulator set at 50 psi 19 lb injectors. to run 24 lb injectors can I change the computer to a cobra or any other computer or is it best to buy a chip I dont want to buy a new mass air because I have the 80 mm but its set for 19 lb injectors. if I need a chip what is the best one. or what is the best computer
Old Jul 31, 2008 | 11:20 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: computre help
lets see... $400 for a new chip. $1600 for a new computer.
stop being stupid, and buy a new maf
Old Jul 31, 2008 | 11:55 PM
kremer306's Avatar
kremer306
your nuts I dont know where your getting your parts I can get a chip programmed for 24 lb injectors for about 150 and I didnt know if any 5.0 computers came programmed for 24 lb injectors. i thought i the 93 cobras came with them but not sure
Old Aug 1, 2008 | 12:21 AM
kremer306's Avatar
kremer306
will the newer maf 94-95 calibrated for 24's work on my car. the reason I would like to use one of them is they have the flat face and will bolt tothe intake I made. how do I get pic to upload every time it says file to big
Old Aug 1, 2008 | 02:18 AM
jtmustang's Avatar
jtmustang
93 cobras had 24 lb inj's...
Old Aug 1, 2008 | 05:52 AM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: kremer306
nope... because stock MAF's arent calibrated to a certain injector size
Old Aug 1, 2008 | 11:30 AM
jtmustang's Avatar
jtmustang
for the pics open up a photobucket account and then u can resize smaller or whatever.
Old Aug 1, 2008 | 11:57 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: kremer306
yeah a cheap ace one that'll perform, like what you paid for it = cheap..quality don't come cheap nor does proper performance
wildmanford
Jan 6, 2008 08:51 PM
kylebonk
May 24, 2007 12:16 AM
