another stupid DIY TT build
Its been awhile in the making, but i'm on the down hill now. here's some pics.
before clean up and heads
after
intercooler
hotside pipes
passenger side turbo mounted, its close, but it clears everything
drivers side turbo my goal was to use as little piping as possibe and I had these piece pipes with flanges that bolted to my header flange so I made them work.
both mounted
passenger side pipe to intercooler, its done now, perfect, looks good for the welder i'm working with
more to come soon.
after
intercooler
hotside pipes
both mounted
more to come soon.
Its a stock block (unfortunately) bored, forged pistons and rods. Main girdle with main studs, Windsor Jr heads 170cc runners 1.94 1.60 valves, screw in studs, dual springs, stainless valves, 1.6:1 fms roller rocker and fms hardned pushrods. Fel-Pro 1133 MLS gasket with arp head studs holley systemax upper and lower with a 1 inch spacer. 42lb injectors c&l 76mm blow through, intercooler. aftermarket 2" aluminum radiator, adjustable fpr.
The turbos are the .60/.63 t3's.
Trans is an AOD with 4r70w stamped steel drums mechanical diode kevlar bands and clutches a+ servo B&M 2800 stall. with a B&M hammer shifter.
Running MSD 6 BTM ignition with boost timing retard. and NGK ur6 plugs (2 steps colder) 3.55 gears.
still have suspension to do but am gonna get it running first.
I'm lookin for about 500 rwhp but we'll see. i'd like anyting about 450.
Its been awhile since pesky school got in the way of me finishing it. But It is on the brink of starting, That should happen tomorrow.
So here's the pictures!!!
Here's the drivers side down pipe just finished wrapped.
drivers side turbo pipe to intercooler
same pipe at intercooler
another angle
passenger side pipe
same pipe at turbo
BOV shot
final charge pipe
another shot
passenger side set up
another shot
drivers side set up
another shot
drivers side down pipe from below
another shot from below
passenger side down pipe from below
and another shot
It WAS a t-5...but thats garbage, so I have an AOD now with 4r70w drums and the works, B&M 2800 stall
fresh driveshaft
tranny oil cooler, all looks nice buttoned up underneath
another angle
passenger side pipe
same pipe at turbo
BOV shot
final charge pipe
another shot
another shot
drivers side set up
another shot
and another shot
fresh driveshaft
