Nitrous
Old Sep 7, 2008 | 05:40 PM
grnstang's Avatar
grnstang
Default Nitrous
Hey just wondering on your thoughts. I wanna spray my stock motor. It has forged internals correct? I want to get a cam and RR's, it will be tuned for it, i was thinking of a full throttle switch. What else should I do? Any thoughts? Really don't know anything about nitrous setups
Old Sep 7, 2008 | 07:12 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
get a wet kit, purge kit, and bottle heater and a gauge to see what pressure is at so you know if you need to switch on the bottle heater in order to raise bottle pressure to optimal range of 900 psi or above, heck this past summer I cracked my bottle after car was setting in the sun and it was close to 1200..at 1200 it'll hit hard but I never run pressure up that high generally the bottle heater has a temp sensitive switch that cuts off heater when bottle reaches 85 degrees
Old Sep 7, 2008 | 08:29 PM
grnstang's Avatar
grnstang
alright, sweet. so you think it's a good idea for me to spray it? is it safe?
Old Sep 7, 2008 | 08:34 PM
Venomantidote95's Avatar
Venomantidote95
Yes heater, gauge, are a must. Wet kits are supreme but it does come down to your wallet, whether you want it hooked to the TB for full throttle on or a button where you can grab it when you want it makes no difference it works great either way, i have mine on the TB where i dont get antsy and smoke the the tires, i had it on a button to start with and it was too tempting to grab it too soon, for me it is easier to control my foot than my hand, it is really a preferance thing.
a tune isnt a must but it is a good idea i dont have a tune and mine works great, i just have to manually adjust my timing which if you dont go over 150 you can do it on 10* and 93 oct, any higher and i suddest a timing control of some sort, if you have a 96 or later you can just about spray what you want the computer will add and subtract timing more efficient than the obd1 cars, plate kits are the best option.
I have the TFX kit for my trickflow topend, i dont have a tune i did get the bottle heater purge and accessories kits! if i can help any just send me a pm! well now that i read your whole list i know what you have duh!! 150 will be fine on 10*
Old Sep 7, 2008 | 08:44 PM
mjr46's Avatar
mjr46
you'll be fine just spray a 100 shot and things won't get out of hand!!
Old Sep 8, 2008 | 02:35 PM
grnstang's Avatar
grnstang
alright good. i'll probably get a 70 mm TB and maybe a bigger MAF and intake itself. along with the nitrous setup and cam.
Old Sep 9, 2008 | 02:19 AM
brynfiv's Avatar
brynfiv
The bigger TB and maf meter would be a nice compliment, but keep in mind it's not a necesity. Nitrous brings its own oxygen. I've heard alot of great things about comp cam's nitrous hp cams. They make good power with or without the bottle.
Old Sep 9, 2008 | 02:34 AM
primetime5.0's Avatar
primetime5.0
a window switch would be good too
Old Sep 9, 2008 | 03:14 AM
302army187's Avatar
302army187
10* timing, highest octane pump fuel you can get, 1 step colder NGK plugs, get a 190lb fuel pump (just to be sure your old one is up to par)
id start with a 75shot, then move up to 100shot, 100shot for me is really nice, i really enjoy it.
but heres a warning from my personal experence.
my valve springs where weak, and had some valve float going on, so i got a backfire into my intake, all it did was pop the intake gasket, but its something you might wanna think about.
id recomend a tear down, replace the head gaskets with 1011-2 felpro gaskets, get your valve springs checked while your in there, and replace your intake gaskets (dont use that cork crap)
heck, if your car looks mostly stock, id hide the nozzel under the intake tube, mount the silinoids under the fender, and make it real stealth.
nitrous is fun, but if your car's not set up right, you could be in for trouble.
Old Sep 9, 2008 | 06:41 AM
grnstang's Avatar
grnstang
alright, thanks. i'lll make sure and look into all of that
