95 h/c/i swap
Old Sep 13, 2008 | 10:51 PM
95stang gt's Avatar
95stang gt
Default 95 h/c/i swap
hey guys whats up im interested in doing a hci swap and i have a set up in mind and i just wanna see what u guys thinkk aobut it and if that is everything i need. afr 185cc holley systemmax II intake elbow bbk 70 mm throttle body a comp cam with new hydrolic lifters 1.7 rr harden push rods arp head studs. tell me whats u guys think and if thats everything i needlook forward to hearing from u guys thanks
Old Sep 13, 2008 | 10:53 PM
94StinkinLincoln's Avatar
94StinkinLincoln
pm me, i got some stuff that works the same as what ur thinking about getting, mine just has a few miles on it.
Old Sep 14, 2008 | 12:53 AM
OnyxCobra's Avatar
OnyxCobra
depending on the cam you'll probably have to get the stock pistons notched to run the AFR 185 heads. Other than that you may wanna do some maintenance stuff like a timing chain, water pump, etc.
Old Sep 14, 2008 | 06:16 AM
95stang gt's Avatar
95stang gt
i meant to put in timing chain too but the cam is a comp cam extreme
heres a link to it
http://www.latemodelrestoration.com/...0%201&comp=LRS
Old Sep 14, 2008 | 11:25 AM
grnstang's Avatar
grnstang
sounds like a good build man good luck
Old Sep 14, 2008 | 04:03 PM
kweb288's Avatar
kweb288
dont forget injectors, and upgraded maf calibrated to those injectors, new fuel pump to support the new injectors so you dont run lean....
Is your car manual or auto?
if it is an auto car you may need to run a bigger stall converter so your car doesnt die,
Old Sep 14, 2008 | 04:16 PM
95stang gt's Avatar
95stang gt
yea i would but just dont have the money for it all and its a manual
Old Sep 14, 2008 | 04:18 PM
kweb288's Avatar
kweb288
well then keep saving because thoser are necessities
Old Sep 14, 2008 | 04:20 PM
drhoward's Avatar
drhoward
Penis Mod Erator
afr 185's are pretty big heads for a stock displacement 5.0
Old Sep 14, 2008 | 04:26 PM
95stang gt's Avatar
95stang gt
would u get 165cc?
