mid 14s?
Old Sep 16, 2008 | 08:08 PM
foxbod90's Avatar
foxbod90
Default mid 14s?
what would it take to get my 90LX with AOD to run mid 14s all day long? it already has CAI, 65mm TB, and cat back flowmasters.
Old Sep 16, 2008 | 08:18 PM
86 5.0L's Avatar
86 5.0L
have you taken it to the track as-is?
if your lucky it already runs that, whats slowing you down is that AOD, a shift kit would be a nice start, add a set of stick tires and higher stall and you'd be at mid 14s comfortably
Old Sep 16, 2008 | 08:22 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
sticky tires, gears and shift kit and you might break 13.99's if your engine is still strong
Old Sep 16, 2008 | 08:35 PM
foxbod90's Avatar
foxbod90
i run low 15s as of right now and it has 133k which ive heard its got alot of life left
Old Sep 16, 2008 | 08:39 PM
foxbod90's Avatar
foxbod90
traction doesnt seem much of an issue. it grips pretty good
Old Sep 16, 2008 | 11:00 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ditch the DOA and with sticky tires and exhaust you should be low 14's easy
Old Sep 16, 2008 | 11:29 PM
raven_ghostwolf's Avatar
raven_ghostwolf
gears 3.73 should be fine with out killing your MPG totally, Have you bumped your initial timing yet? 14 degrees should work well.
Old Sep 16, 2008 | 11:37 PM
93 LX FiveO's Avatar
93 LX FiveO
gears would be ur best investment
my old aod had similar mods and ran low 14's all day with factory 3.27's
Old Sep 16, 2008 | 11:38 PM
92stangerang's Avatar
92stangerang
like raven said... gear. w/ basic bolt ons you should clear 14s (h or x pipe O/R, Exhaust, CAI, Tune, AND some Drag radials) maybe alum driveshaft. if your not worried about MPG. then go with 4.10s. is so, like rave said 3.73s.
Old Sep 16, 2008 | 11:57 PM
kweb288's Avatar
kweb288
wouldnt recomend putting a shift kit in it man.......... put one in my car with 109k miles on it and blew up the trans with in 1000 miles! (was driving very aggresively!) But before i put the shift kit in, i had my 4.30s and let me tell you that woke up the car A LOT! do at least 4.10's for an automatic
