Engine Cleaners
Old Sep 28, 2008 | 09:05 PM
yaris0128's Avatar
yaris0128
Default Engine Cleaners
My engine is really dirty and is causing it to run really rough. Anyway is there any cleaning products anyone could recommend for me to try out to help the problem. Basically when I say dirty Ive got build up everywhere. The inside of that air intake is BLACK and its causing my 5.0 to run really idle super rough and die. So if anyone has got some good product ideas thatd be great, Thanks.
Old Sep 28, 2008 | 09:10 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
^^^^^^^^^I doubt that is the root cause, you most likely have a vaccum leak or a misfire, has it had a tune up lately??? could have secondary ignition probs, like cap, rotor , and wires, or plugs, if there are no internal engine issues like a burnt valve or so then start with externalities first
Old Sep 28, 2008 | 11:50 PM
yaris0128's Avatar
yaris0128
Ya I just had a tune up done two weeks ago and 3 weeks ago I had a mechanic check it out and they said they couldnt find anything wrong except a bad oil pan gasket that leaks oil a bit and that the engines really dirty.
Old Sep 29, 2008 | 10:07 AM
USMC1775's Avatar
USMC1775
They make engine degreaser for the actual outside of the engine, just make sure to cover the intake, alternator and battery when you do it.
As for the inside of your intake tube... remove it and try engine degreaser when its not on the engine, then get yourself a K&N filter
Old Sep 29, 2008 | 10:16 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Gunk foamy works pretty well. Make sure you cover the distributor. As mentioned above, I doubt it's your drivability issue. As far as your mocanic, maybe it's time for a new one.
Old Sep 30, 2008 | 07:59 PM
yaris0128's Avatar
yaris0128
Ya I just bought the mustang a month ago and I had it looked at to see if there was anything possibly wrong with it. Ill take it to a different place for that specific problem. Maybe they will come up with something.
Old Sep 30, 2008 | 08:09 PM
jman511115's Avatar
jman511115
Try cleaning your maf sensor too. If the intake is gunked up then the sensor might be too, and causing a rough idle and other problems.
Old Sep 30, 2008 | 09:28 PM
306stang's Avatar
306stang
+1 on the new mechanic.
Clean out your intake and some of your Throttle body components, egr/iac etc.
Then get back to us.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
