timing
Old Oct 7, 2008 | 02:19 PM
mustangsneverdie's Avatar
mustangsneverdie
Default timing
what will the timing be set at with the E-303 cam I'm gonna try and time it right 2nite if anybody can help
Old Oct 7, 2008 | 03:16 PM
calfroper_06's Avatar
calfroper_06
should be 10*
Old Oct 7, 2008 | 03:48 PM
Timspony's Avatar
Timspony
SVT Section Moderator
10 deg. would be stock...you can go higher then that with super unleaded...timing = power
Old Oct 7, 2008 | 03:53 PM
mustangsneverdie
well the problem is that it just gradually gets warmer 180* this mornin (usually just 170*) switched to under the hood this mornin when I got to school and done pretty good but I drove it about 5 mi. and it got up to about 190* now I know that's not hot but I figure if I drive it more than 30 mi. or so it will run hot and I usually don't go over 60 and I'm just trying to figure out why it would do it
Old Oct 7, 2008 | 04:00 PM
calfroper_06
could be alot of things, hows your radiator flowing, what about your fan, does it seem like the t-stats sticking or does it open like it should
Old Oct 7, 2008 | 04:16 PM
mustangsneverdie
fan works good rads brand new(stock oem from advance) t-stat is a 160* and does like it should
Old Oct 7, 2008 | 04:29 PM
calfroper_06
what about the water pump, does it show good flow through the radiator when the t stat is open
Old Oct 7, 2008 | 04:30 PM
calfroper_06
what do you mean by this
Old Oct 7, 2008 | 04:44 PM
Timspony's Avatar
Timspony
Perhaps you have an air pocket in the cooloing system?
Old Oct 7, 2008 | 05:53 PM
mustangsneverdie
last night I put it in between the rad and the bumper and when I got to school this mornin I put it i between the rad and pullies?
