charging problems please help
Old Oct 7, 2008 | 11:43 PM
mostdef's Avatar
mostdef
Default charging problems please help
just like the title says i really need help i have an 87 gt ttop hci, stock internals, all the other goodies, ok at idle my car charges very well always to notches above half way mark being i bought a pa alternator no more than a year ago...the car really isnt driven excepts for weekends and the thursday irwindale track day over here in pasadena ca. well the car charges fine at idle but when i rev the motor the idle drops all the way to the red mark and has even turned off...i have tested the alternator at the local auto zone and everything seemed fine but it doesnt make sense...i have checked all the grounding and even installed thicker 4g wire being that i had it spliced to the stock wiring, but also always worked fine...can any one help??? any info will do...thanks
Old Oct 8, 2008 | 08:04 AM
calfroper_06's Avatar
calfroper_06
check your inline fuses
Old Oct 8, 2008 | 11:17 AM
mostdef's Avatar
mostdef
using the newly routed 4gauge wire w/ 200 amp fuse between doesnt use the stock inline fuses any more...
Old Oct 8, 2008 | 11:53 AM
kaggriff's Avatar
kaggriff
i assume that the 4 gauge wire is to feed current back to the battery. sounds more like the problem is in the plug and wiring that is used to excite the alt. With out proper voltage and ground in the plug the alt is a boat anchor.
Old Oct 9, 2008 | 12:56 PM
mostdef's Avatar
mostdef
well if that were true it wouldnt charge at all..right??? with out proper grounding the car would run on battery the whole time
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
