Finally painted
man it looks nice man i really like the 2 tone and it has been a while since you have been on here huh?
so how is the 347 runnin? comeon throw a few pics of that nice motor in here man.
congrats on the paint job did u do it or? curious what do u have in to the paint job?
The paint job only cost me $1800. He cut me a deal since it took him so long to finish it.
As far as the 347 goes, it needs a tune very bad. The stock computer isn't cutting it.
Here are some engine pics.
Here's an old video of the car at idle right after I finished the 347 build. Please excuse the crappy rear bumper. As you can see. I ditched it not long after this video was shot.
FRANKENSTANG
Engine: 347 c.i. Stroker
LOWER:
Summit 302 block machined for 347
Eagle Forged crank
Eagle Forged rods
Keith Black flat top .040 valve relief pistons
Trick Flow cam dur. 275/279 Lift .499/.510
Pete Jackson Gear drive (noisy)
Milodon high flow oil pump
Milodon 8qt oil pan
UPPER:
Trick Flow Twisted Wedge Track Heat heads (ported/polished)
2.02/1.60 Valves
Trick Flow 1.6 RR
ARP Studs
Trick Flow Upper/Lower intake (ported/polished)
FoMoCo 24lb injs.
BBK 75mm TB
Granitelli 75mm MAF
BBK fuel press. reg.
BBK CAI w/K&N Filter
Drivetrain:
1965 C4 trans (hardened clutches, 33 spline input shaft)
TCI flexplate
TCI 3500 stall
Ignition:
MSD 6AL
MSD 2 step module (stutter box)
Taylor 10mm wires
Exterior:
2000 Cobra RR Cervani hood
Saleen Wing
Weld Draglites (Front) 3.5 Euro Skinnies
Weld Draglites (Rear) w/ 10.5 M/T E/T streets
Suspension:
UPR Tubular K-Member
UPR Tubular A-Arms
UPR Bump Steer kit
UPR coil over kit
MM Caster/Camber plates (4 ways)
Sub Frame connectors
8.8 rear W/C-Clip eliminators
33 spline Moser axles
Spool w/3.55 gears
Moser housing cover
Hey man, nice paint job, what kind of paint and clear did you use on it?? Did you pull the motor to paint the inside of the engine bay or cut it in?? also are you inner wheel wells on?? i can like see the concrete through some pics... Do you have any guess on what horsepower this brings??? thanks alot.. good job on the paint..
And, yes that is a 3 row rad that I had in the car at one time. Now I have another one in that's wider then the one in the pic.
