NEED HELP PLEASE!!
Old Oct 15, 2008 | 04:52 PM
5l4life's Avatar
5l4life
Default NEED HELP PLEASE!!
I have an 88 lx with a 306 and basically stock bottom end. My question is i want more power. what would be th better way to go, Nitrious, supercharger,or stroker?
Old Oct 15, 2008 | 05:50 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
How much you got to spend? Big difference in price between those 3.
Old Oct 15, 2008 | 06:22 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
price is the main factor as pro50sc stated....also do you want consistent hp cause that'd rule out NO2
Old Oct 16, 2008 | 03:13 PM
blake v's Avatar
blake v
I'd either go with a super charger or stroke it. Nitrious is just alot of wear and tear on your motor and like they said its not constant power you just get it in bursts. If it was my car and tha bottom end was already in good shape i would do tha super charger no use tearing down a motor that already runs.
Old Oct 16, 2008 | 03:18 PM
mjr46's Avatar
mjr46
stroke it then, that's what I did...a 347 and it has the power I want
Old Oct 16, 2008 | 04:50 PM
5l4life's Avatar
5l4life
I have a 88 lx with the following mods, engine is bored to a 306. Stock heads are shaved, ported and polished, E-303 cam. 1.7 roller rockers, clevite timing chain and gears. K&N inbox filter. Intake spacer.Under drive pullies. 3 core rad. Electric fan(installed direct). Long tube headers. H-pipe. No cats. 40 series flowmasters. 3.73's. Aluminum drive shaft. Tremec T-5 trans. Pro 5.0. lowered 1". 275-40-17's. Sub frame connectors. larger diameter swaybars Front and rear and a few other minor mods Etc. 2to 3 grand is about the budget limit for this year. But i was also thinkin about Heads and a upper and lower intake. But so very confused. Any suggestions would be greatly appriciated!!
It's a great honor to be able to chat with you guys.
