Why does my car do this??
Old Oct 17, 2008 | 11:29 AM
white-lightning's Avatar
white-lightning
Default Why does my car do this??
Ok when ever i get 1/2 throttle it tries to bog out, but if a hit hard it comes alive. what can i check?
Also it hard developed a valve trian knock?how do you solve this by compression drop, how do you adjust the valves??
Old Oct 17, 2008 | 11:33 AM
USMC1775's Avatar
USMC1775
If it was carbed, Id know the prob, but since it says 90 in your info, youre FI.
It could be a few things, fuel related, spark related, or air related. Sounds like a fuel problem because of your positioning of the skinny pedal.. check your FP first, that could lead you somewhere
As for the valves, you have to remove the VCs, and its kinda obvious from there if youve done it before
Old Oct 17, 2008 | 02:12 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
try cleaning the maf sensor or run a koer test and see if any codes come up, there may be an issue with the tps
Old Oct 18, 2008 | 11:48 AM
white-lightning
Ive never delt with valve knock, and tips or other thread with a how to?
what should the FP be?
Old Oct 18, 2008 | 11:50 AM
white-lightning
Its got a new tps on it ill try cleaning out the tps
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
