nitrous!
Old Oct 20, 2008 | 04:37 PM
92foxlx8967's Avatar
92foxlx8967
Default nitrous!
i am installing a zex dry kit i have done everything but the switch can anyone help me out on how to wire up the switch? its on a 92 lx 302
Old Oct 20, 2008 | 06:31 PM
Jon82387's Avatar
Jon82387
what kind of switch are you going to run? just a standard toggle to turn the spray on?
I would highly recomend a Window Switch, and im assuming you have a WOT switch from the kit right?
Old Oct 20, 2008 | 09:37 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
are you refering to the activation/throttle switch??
Old Oct 21, 2008 | 01:15 AM
dimebag's Avatar
dimebag
its very simple
go from power to your on/off switch, that goes to the red wire, the white(i believe) from the box goes to your tps, and the black gets grounded, that should be it
set the box to your tps and you should be good to go
fwiw, ive dealt with the zex dry kit on a 5.0 before, it works, it pulls good(125 shot) but i wasnt happy with it, and would much rather the wet kit, that i use
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
