charging problems please help
Old Nov 8, 2008 | 07:44 PM
mostdef's Avatar
mostdef
Default charging problems please help
i have an 87 ttop full bolt on hci, tfs heads, f cam, rpm 2 upper and lower and pa 130 alternator, it doesnt charge what so ever now, it runs on battery. i got a new alternator shipped from pa, checked all fusible links even ran them direct, as well as ran 4g wire from the alternator to the battery. it doesnt seem to charge, i have gotten to the point where i want to run new wires all the way thru. does any one know where i can find a charging diagram?? or does anyone have any other ideas?? anything will help thanks
Old Nov 8, 2008 | 07:57 PM
1988TTOP's Avatar
1988TTOP
http://www.veryuseful.com/mustang/te...nks-ign-ac.gif
this should help
Old Nov 8, 2008 | 08:03 PM
1988TTOP's Avatar
1988TTOP
how did u do the 130amp alt did u hook all of it up right
http://www.mustangcentral.net/tech/alternator.html
Old Nov 8, 2008 | 08:05 PM
calfroper_06's Avatar
calfroper_06
88ttop havnt seen you in awhile did you ever get that thing running
Old Nov 8, 2008 | 08:08 PM
1988TTOP's Avatar
1988TTOP
yea i did and broke it 5 min in the ride
Old Nov 8, 2008 | 08:14 PM
calfroper_06
whats wrong now? as for mostdef check your grounds and take the alt to the local autopart store and get it check
Old Nov 8, 2008 | 08:21 PM
1988TTOP's Avatar
1988TTOP
clutch cable and long tubes didnt like each other
Old Nov 8, 2008 | 10:56 PM
mostdef's Avatar
mostdef
thanks diagram is great....as for the pa alternator...yeah a simpl plug and play deal
Old Nov 9, 2008 | 07:11 AM
calfroper_06
i would get the alt. tested before you reroute everything. i know its new but hey you never know. also with motor running take a volt meter and test the output side of the alternator if nothing wiggle your connector alittle and see if you get anything, this is to make sure its not just the connector, also you need the best ground possible so check them and clean them as nessesary
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
