emissions
Old Nov 17, 2008 | 06:04 PM
q8stang's Avatar
q8stang
Default emissions
if i removed my smog pump and egr will the car pass emissions? the car is 100% stock 1990 5.0 and iknow what smog pump does but what does the egr do? any pros cons in removing it?
Old Nov 17, 2008 | 06:23 PM
saleenpride1986's Avatar
saleenpride1986
nope. But the benefit to removing = gain in hp from less applications needed to be ran by motor.
Old Nov 17, 2008 | 06:45 PM
ALMOST STOCK's Avatar
ALMOST STOCK
I doubt that you'll pass the visual with the smog pump and EGR missing, let along the actual test.
Old Nov 17, 2008 | 07:47 PM
q8stang's Avatar
q8stang
is the gain worth it?
Old Nov 17, 2008 | 07:50 PM
saleenpride1986
unless you swap out all emissions items and the likes before a race, there wont me a noticeable difference.
jtmustang's Avatar
jtmustang
Just keep the parts so u can reinstall and pass emissions...
....haha no emissions up where i live...
Old Nov 17, 2008 | 07:52 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I hope that your not infering that there are no cons to removing the EGR???.....cause if you understood what egr is for and what it does the proper answer is:YES!!! there is a con to removing the egr.....which it is refered to as exhaust gas recirculation and at certain times the egr circulates exhaust gases into the cumbustion chamber to lower NOX....which is a greenhouse gas the egr by injecting exhaust gases into the cumbustion chamber lowers cylinder temps which inturn lowers NOx output, without egr on the 5.0 you most likely will not pass the actual test as NOx emissions will be above the max limit and if you have a visual inspection you will surely fail for missing smog and egr, the smog/thermactor air injection is only operative in warm up to inject air into the exhaust stream to heat up the cats quicker to bring them into their effectiveness range
q8stang's Avatar
q8stang
wow i should register the car in ur name!! so i wont worry about emissions
Old Nov 17, 2008 | 07:58 PM
q8stang's Avatar
q8stang
so what i understand is i should just leave it because it wont make alot of difference
and i need to pass emissions
Old Nov 17, 2008 | 08:06 PM
mjr46's Avatar
mjr46
^^^^Exactly, egr will not hurt performance enough for you to even notice, most remove it cause they are unable to figure out how to repair it if it is malfunctioning.....heaven knows it can't be for weight reduction cause your lucky if the valve and selonoid weight a total of 5 lbs
