removing upper intake
Old Nov 25, 2008 | 06:20 PM
q8stang's Avatar
q8stang
Default removing upper intake
everything is removed from the upper intake except for the hose that runs to the vacuum tree the clamp are soo old maybe that i have never seen one like it . does any one know how to remove them? and i also noticed that in the bold that is closest to the fire wall on the upper intake the is this wierd piece of metal tha connects it to the lower manifold is it okay to dispose this piece of metal?
thanks
Old Nov 25, 2008 | 06:36 PM
camaroeater's Avatar
camaroeater
i think the hose you're talking about is the brake vacuum hose, try breaking the hose loose with some plyers that won't tear it. That metal rod that goes from the lower intake to the firewall is a support, you can get rid of it.
Old Nov 25, 2008 | 06:38 PM
q8stang's Avatar
q8stang
i tried evry thing and that clamp wont go lose so basicly that is the only thing stoppning me from removing the upeer intake
Old Nov 25, 2008 | 07:53 PM
saleenpride1986's Avatar
saleenpride1986
Well if you have everything else already loosened up then if that hose is the very last thing that is connected to it, you should be at least able to move if not pick up the intake a good few inches until the hose is taught. If you can't do that, then there may be something else that you still haven't loosened, but as you said "everything is removed from the upper intake"
Old Nov 25, 2008 | 09:08 PM
q8stang's Avatar
q8stang
yes but the hose is short and the clamps are almost imposible to remove
Old Nov 25, 2008 | 09:24 PM
mustangsneverdie's Avatar
mustangsneverdie
then take it loose from the brake booster
Old Nov 25, 2008 | 09:32 PM
USMC1775's Avatar
USMC1775
You have a new Mustang in your sig every week? (mustangsneverdie) Let me guess.. this one is the 4 eye before it was a 4 eye before it was a 89 lol
Old Nov 25, 2008 | 09:43 PM
crusin92red5.0's Avatar
crusin92red5.0
i think your talking about the crappy clamps that you pinch and that opens them up. Just cut the clamp with some dykes and if you really want to get the intake off cut the hose until you can fig out how to break that clamp
Old Nov 25, 2008 | 10:27 PM
mustangsneverdie
nope just one I used to have
Old Nov 26, 2008 | 02:26 AM
q8stang's Avatar
q8stang
will a normal clamp that has a screw in it work for the vacuum? if it will ill just cut them
