removing valve covers
Old Nov 26, 2008 | 04:38 PM
q8stang's Avatar
q8stang
Default removing valve covers
ok so on the drivers side i removed all the bolts for the valve cover but it wont break lose i was told to hit it with a rubber mallet.
the passenger side valve cover i removed 5 bolts then the 6th bolt is almost imposible to reach since there is a hook that is in front if it is there away around this hook?
Old Nov 26, 2008 | 04:51 PM
.boB's Avatar
.boB
The valve cover is probably glued on with silicon sealant. Put a putty knife in the crack and gently tap it in. That usually breaks the seal enough so you can get it off.
I'm not sure about the hook you're referring to. But it's probably the factory lift hook? Can you take it off?
Old Nov 26, 2008 | 05:11 PM
cleanfitty's Avatar
cleanfitty
The engine lift hooks bend in toward the engine when the engine is pulled and that will cause you not to be able to get a socket in there. You have to remove them. The drivers side is a peice of cake, but the passenger side can be a **** to take out because of the somg tubes, trans dipstick, etc.
rmodel65's Avatar
rmodel65
Yukon Cornelius
remove the upper intake, my hooks arent in the way
Old Nov 26, 2008 | 10:05 PM
q8stang's Avatar
q8stang
the upper intake is removed so if the hook is not that important can i just hammer it so it can bend ?
Old Nov 27, 2008 | 12:16 AM
jtmustang's Avatar
jtmustang
just take the hook off
Old Nov 27, 2008 | 12:50 AM
95greengt's Avatar
95greengt
yeah id just take it off if ya can
Old Nov 27, 2008 | 09:22 AM
DriftingRz's Avatar
DriftingRz
Hammers solve EVERYTHING
Old Nov 27, 2008 | 03:40 PM
q8stang's Avatar
q8stang
yeah if it will make it easyer im using a hammer
Old Nov 27, 2008 | 06:15 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I just use a 1/4 socket and a universal to reach down in between cover and hook, I never really have to remove them......pry a screwdriver between head surface and cover and pop it loose
