8.8 Rebuild HELP!
I have tried searching with no success. I need to know some info on my rear...
Situation: One wheel Peel Car: 1989 Ford Mustang GT M5 I know it is the 8.8 rear, but I am not sure what rebuild kit I need to refresh my limited slip. I am assuming it is a 28 spline, but let me know if I am wrong. What do I need? Threads on rebuilds would really help, as would links to rebuild kits you would suggest. I am also thinking I may want to replace the bearings also. Please let me know what I need. Also, how hard is it to install 3.73 gears while I am at it? How hard is it getting them spaced correctly to eliminate the howling? Thanks! |
Originally Posted by Slakkr183
(Post 5711831)
If I dont do the gears this time, how will I ever learn?
Anyone else have any suggestions? |
i think it is a pretty hard job for gears i had a guy do it for me on my 07 and i had a gear whine from hell then i had a shop do it for me with another set of gears and no gear whine
(Post 5711968)
I would recommend for a shop to do it since you have never done one before. $200 does not sound like a bad price. Also you can go to Steeda's website and look up the level of difficulty and the amount of time required to install the part. Here is a link. http://www.steeda.com/products/ring_pinion_sets.php
Go w/ the carbon fiber kit from Summit. Here is an article
http://www.mustang50magazine.com/tec...ild/index.html As already stated, you should have a shop do the gears but the o/h of the trac lok is fairly simple. |
you can learn to do it on your own. he's right, you will have to buy some tools though. when i shopped around the price was around $350. i read a lot, bought the tools i need, and took my time. no problems, no noise. in the end i got new tools and learned something in the process. however there is something to be said for paying someone else to do it, it gets done quicker and it comes with a guarantee.
