exhaust
Old Jan 5, 2009 | 08:57 PM
mustangsneverdie's Avatar
mustangsneverdie
Default exhaust
ok I'm new to the efi cars and I'm puttin on the o/r h-pipe from the 85.My ques. is do I have to hook up the emissions pipe that runs down to up under the car or can I just get a pipe crimp it up at the top(I already have the stock h-pipe off)
Old Jan 5, 2009 | 09:14 PM
83gtragtop's Avatar
83gtragtop
Well if you are buying a off road H-pipe they will usually have a small tube built in for your smog tube to connect to.
vvvvvvv
If you are having a H-pipe fabricated by a local exhaust shop then I would just remove your smog pump and all its attachments. I'm assuming you don't not have to pass smog or inspection in your area.
Old Jan 5, 2009 | 09:30 PM
mustangsneverdie
well see I already have the o/r h-pipe and it has the pipe built in but it's crimped do I need to take a piece of tubing and crimp it for up under the hood
Old Jan 5, 2009 | 09:35 PM
83gtragtop's Avatar
83gtragtop
You should have a rubber tube already running from your smog pump to your H-pipe if you have a stock midpipe in there.
Old Jan 5, 2009 | 09:54 PM
Explosive's Avatar
Explosive
I'd get a smaller belt and ditch the pump.
I had my trucks exhaust done, and now the air pump just dumps into the atmosphere, and the damn thing humms like a ****, next on my list is a shorter belt so it doesn't operate anymore...
Old Jan 5, 2009 | 10:20 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
take all the emmision stuff off and run a short belt. just be sure to plug the holes in the back of the heads
Old Jan 5, 2009 | 10:32 PM
mustangsneverdie
I'll prolly get a short enuf belt that I can take off the a/c too
Old Jan 5, 2009 | 10:35 PM
projectresto83
M.A.D. Motorsports
Its not that easy there my friend. If you try that you can't run the tensioner and then you can't get the belt on. That is why you see people with compressors that are unhooked but still in the belt route. Get a a/c delete for like $45 and then have fun .
Old Jan 5, 2009 | 10:39 PM
Explosive's Avatar
Explosive
God, I can't wait to make that damn air pump stop, it's ridiculous, once the motor hits the rpm range the exhaust comes in, the noise from the damn pump drones it out. ERGGG
Old Jan 5, 2009 | 10:45 PM
mustangsneverdie
is it the p/s pump that you can bypass instead of the a/c
