gasket set ?
Old Jan 10, 2009 | 12:24 PM
symonds86's Avatar
symonds86
Default gasket set ?
what gasket set do i need for my engine build, its a 69 302 im running aluminum heads, and the vic jr efi intake if that matters.
thanks guys
Old Jan 10, 2009 | 12:29 PM
FORD TOUGH's Avatar
FORD TOUGH
Complete rebuild set? Has it been bored?
Old Jan 10, 2009 | 12:37 PM
symonds86's Avatar
symonds86
o sorry yea its a 347 bored 30 over. i just curious what most of you guys use and if i need a special set for aluminum heads? i have heard a regular sets can dig up the head around the fire ring
Old Jan 10, 2009 | 12:56 PM
FORD TOUGH's Avatar
FORD TOUGH
Your machine shop should be able to order gaskets, or you local parts store. Be careful with some of the gasket sets because they come with the wrong intake gasket. Felpro and Victor are good gaskets. Check your old gaskets with the new ones on make sure all of the holes line up correctly.
Old Jan 10, 2009 | 03:42 PM
FORD TOUGH's Avatar
FORD TOUGH
You will need to get gaskets that fit your intake port on your head.
Old Jan 10, 2009 | 07:11 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I get the gaskets seperate as can get better quality for that way, I use the fel pro- 1011-2 head gaskets, a standard timing chain gasket kit and fpp-1250 intake gasket and fpp 1450 header gaskets and 1 piece pan gasket and reusable valve cover gaskets
Old Jan 10, 2009 | 07:25 PM
FORD TOUGH's Avatar
FORD TOUGH
Do you mean the perma dry valve cover gaskets? They are really nice.
Old Jan 10, 2009 | 08:16 PM
mjr46's Avatar
mjr46
I tried those but since I have the flat rail ford racing valve covers, those didn't fit the pattern of my valve cover to well, it says in the instructions for my valve cover that they wouldn't work, either way the perma dry are nice
GimpyHSHS
19
Dec 19, 2023 01:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Dathan
Oct 5, 2015 05:52 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
