starter problems still
Old Jan 12, 2009 | 03:57 PM
gtmustang1090's Avatar
gtmustang1090
Default starter problems still
i replaced ignition switch, starter, celinoid, and starter wire. and the starter is still hanging up and wont disengage from the fly wheel.. any ideas
Old Jan 12, 2009 | 04:36 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
It doesn't disengage at all?
Old Jan 12, 2009 | 07:22 PM
Catchpole's Avatar
Catchpole
Mine did this and it was the starter relay, a quick fix is to gently but firmly hit it with a hammer/decent size wrench...Seriously... it's just not disengaging, or at least mine wasn't.
I did that once or twice and then I just replaced it.
Old Jan 12, 2009 | 08:19 PM
camaroeater's Avatar
camaroeater
+1 on tapping the solenoid to disengage the starter. The first solenoid I installed turned out to be defective, then i bought a more expensive one and the problem was solved.
Old Jan 12, 2009 | 09:46 PM
gtmustang1090
Angry
i am on my 3rd celiniod because i returned the others.. and then went and got a more expensive one you could feel the difference in weight.. no help.. the car will crank and start just the starter wont disengage after i start it.. then i have to turn the car off and its still cranking off the battery till that dies or i hop out and pull the cable off the battery.. someone told me the one red wire going into the celinoid is what tells the starter when to engage and disengage.. if this isnt it i have no clue.. i finally got talked into buying a ford and its been the biggest mistake that ive made so far since ive had it.. the car is killing me sitting in the driveway.. i wanna go tear the streets up alittle with it
Old Jan 12, 2009 | 10:04 PM
projectresto83
M.A.D. Motorsports
My 89 4 cyl did that. I got tired off it and sold the car.
I didn't have a title for it anyway. Then my cougar started doing it, I hooked up toggle and a push button start and solved that one. I loved that car lol
Old Jan 12, 2009 | 10:14 PM
gtmustang1090
yeah i wanna keep the car like with a key start.. im not quite sure what the issue is but it is pissing me off big time .. im gonna try this wire that the local mustang speed shop guys said it sounds like.. if i cant get it hes gonna have the car to figure it out..
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
